I’m home. Excepting the one time that the car needed the little jump box to start it after I forgot that the lights were on, it made the entire 520 miles without a hitch.
Except for the random jump from perfectly smooth tire rotation, to acting like it was gonna have a tire fall off. That annoyance would come and go, and come and go the entire drive. Sometimes perfectly balanced smooth for a half hour, then out of the blue wobbling like a wheel was loose.
On the way down, I thought it was a rear wheel bearing, but after driving the car into the parking deck and making the tight turns as I wound the car up to level 5, the noise seemed to be coming from the front..A distinct groan that could only be a wheel bearing,....but coming from the front instead.
I wasn’t gonna attempt an Auto Zone parking lot swap, so I got in the car and drove.
The vibration came and went the whole way home again. By the time I got w/i about 60 miles of home, I noticed the thing was also wandering a little in the lane.. ( I was thinking that I was gonna loose a wheel at any minute at 80 mph...I almost had to pry my hands off the wheel by the time I got in the driveway...)
When I got it home, I immediately put the front end in the air, and grabbed the passenger side tire at the top and gave it the ole push/ pull treatment.
I’ll bet the tire moved 1/2” in/out.
Went to the driver’s side, same thing...maybe only 1/4-3/8”. Both nuts were so tight I needed an extension on the breaker bar to loosen them.
When you read the symptoms of a bad wheel bearing, guess what it says..
*Erratic Vibration, groaning/grinding, especially in tight turns at low speeds..
I put those things on probably 6 years ago, and the total mileage can’t amount to more than about 2000 miles. They are/ were supposedly Timken bearings..clearly..Nothing to be gained from that brand name.
Nonetheless, Ive just ordered a new set from Summit..Same damn Timken brand as they are “ in stock”. Also ordered a set of drilled/slotted front rotors..guess I’ll have to clean up the calipers, and give them a coat of paint now that I’ve got pretty rotors coming.
It was all good. The car got a little over 22 mpg mostly at 80 mph. If i wasn’t afraid that I was either gonna bend the Tork troll, or loose a wheel and go careening into the crowd while out doing something stupid, I mighta done that...But I didn’t..Maybe next time.
