Here's what the description said about the motor...
74' Ford 302/5.0 short block. Bored & honed .060 over, new cast pistons, block decked, rods reconditioned with chrome-moly rod bolts, new rings and bearings. New Crane Blue Racer camshaft with .512 lift, 284 adv. duration, 228 duration @ .050. Short block built for 16 year olds first hotrod, decided he'd rather smoke dope and act stupid. His dad scraped the project. Delivery possible, e-mail for details. Short block does come with new timing chain and gears installed and cam degreed
Most of the stuff is new. My buddy is trying to convince me to keep everything as is, instead of dropping in a 331 stroker kit, and to just make sure everything is put in right. What kind of power do you guys think it will have w/ the following bolted on:
-Weiand Stealth Intake
-Edelbrock 600cfm Carb w/ electric choke (although my buddy is telling me to get a 750cfm carb)
-Edelbrock Performer Fuel Pump
-MSD Ignition
-Hedmen long tube headders
-2.5" H-pipe
-Flowmasters
I will eventually change the gears to 3:55 and add the torque converter w/ 2400 stall
I might change the cam to something w/ a wider RPM range. The one that is coming is from 2000-5500 RPM but I was looking at a Comp Cam w/ similar lift and duration w/ an RPM range from 1600-6800. The car will be a daily driver and Im looking to get good torque and like 320-375 HP
