Quick Starter Motor Question.
Nov 26, 2020
42
10
18
41
Southern Virginia
I have a quick question for the people here. Have you ever had starter heat soak issues on your Fox? When cold, the starter would crank strong. When hot from driving, the starter would crank very slow, but yesterday it seized. I will double-check my grounds and battery, but they should be good. The starter is only about a year old too :/. I've seen heatshields designed to go around the starter, but I don't know if that is necessary. So, has anyone experienced this? Bad starter? Bad Ground? Thanks.
  • Sponsors(?)
Blandnuts
I don't swallow; I only swoosh
1,165
115
114
The Big T
www.dodo-brown.com
Yes, took it to the store to exchange it and it tested fine on their machine (nice and cold). Luckily, I was wearing my ford jammies and the manager just replaced it. I would need to wait for the starter to cool down and then it would start fine. This was on a modified car with shorty headers.
As far as grounds, I run an extra ground from the negative terminal to the A/C compressor mount.
General karthief
Mod Dude
Aug 25, 2016
19,429
6,465
193
polk county florida
Do a voltage drop test on the cables but honestly it's probably a bad starter, is it a newer style starter with the built in solenoid?
Reactions: 1 user
Boostedpimp
1,172
431
124
NJ
Only time I've ever had heat soak issues with a starter on a foxbody was with mac long tube headers. Otherwise never had a problem with various brand shortie unequal and equal length headers
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,295
6,401
214
32
Hillsborough county
I fixed this issue by using an SN95 or explorer 5.0 starter. You just have to run an extra wire from the solenoid down to the starter.
General karthief
Mod Dude
Aug 25, 2016
19,429
6,465
193
polk county florida
The starter does not have a built-in solenoid.
Easy upgrade, I did it. Hit the link in my post and you'll see how I did it.
Slow crank, no crank can usually be traced to bad cables, commections that will over heat the armature in the starter, so make sure the battery is good (I don't care if you bought it yesterday, don't guess, be sure) and test the cables and the starter.
nickyb
WAIT,you now have a pair?
954
415
93
58
nevada
Even daily driving in this broiler we call Nevada ,long tubes for ten years no heat soaked starter.
Reactions: 1 users
Nov 26, 2020
42
10
18
41
Southern Virginia
Checked all grounds, cables, solenoid, and my battery. All was good. Removed the starter and it was completely seized. Even bench testing it with a behemoth of a marine battery, it wouldn't turn. It just got hot and smoked. Replaced the starter, everything works like normal now.
Reactions: 2 users
