Tips on "rolling" fender wheel wells
6strings
Windsor,CT
I have a '65 fastback that I just did the front disc brake conversion to and switched to 15" wheels & 225/60/15 tires. The problem is that now the tires hit the front of the wheel well when the wheel is turned.
I have been told that you can "roll" the wells with an aluminum baseball bat to get the required clearance. I would be more comfortable with this approach if the car did'nt have a good paint job. I thought about using the sawzall to cut the lower front part of the well and then fold it back using a mallet.
Does anybody have any tips on the right way to do this?
I'm no body guy, but if I was going to try to bend metal that can be seen, I would put something soft against the metal, then beat on the soft thing. Then you end up with a better chance of getting a nice gradual curve, rather than little pock marks.
Soft as in wood, perhaps? Body people use a leather bag filled with shot to form metal. Rubber mallet, maybe? I would say that even using a piece of metal against the body and hitting that with a hammer is superior to striking directly on the body.
There are some other threads, if you do a search with keyword "roll" or fender, you should get more advice.
Good luck.
if your car is already painted, you are definetly going to screw up the paint. On the front wheel wells, i would definetly cut the lips. ON the rear, dont cut the lips. I couldnt roll mine with a bat....never did work. I had to beat mine with a hammer.
Here was some tire shop that would have rolled my fenderlips for 20 euros a side (24$), without possibility of ruining my new paint job, but I decided to mill some 4 mm of my wheel to bring it inner, and changed from 222/60-15 to 225/50-15. They are just so much lower, that with negative wedge kit, they evade my lips now... Now I´ll just have to do the same thing (milling the wheel) to my backwheels...
Never done it, but seems to me that attempting this without removing the paint and fender is just begging for dissappointmnet. Do some research on metal tempering and hammer forming (just like custom bike shops do) and you'll find the answers. There's lots of cool stuff to learn about metal fabrication.
Last year on the way home from Hot August Nights, I somehow caught something that pulled my fender lip down far enough to gouge the sidewall of my tire. I had to replace the tire but to fix the fender lip, I borrowed a similar tool to the Eastwood one from a friend on mine. The tool was easy to use once adjusted properly. It worked real well. I stayed far enough away from the edge so it did not damage my paint. The lip was bent uniformly. I will roll the other side before I return the tool.
Hehe, sorry but I had to ask.. you borrowed the tool last year and haven't returned it yet?
That must be a really good friend! :D
Well, I am behind on things.... Too many other projects to work on. I borrowed the tool in January. I rolled the one fender and replace the tire in mid March. The car has maybe 20 miles on it since I came home from Reno. I am ashamed to say, I haven't wash it yet. It still has all the road grime from the drive home :nonono: Straight into the garage it went. I am going to need to get my butt in gear real quick. There is a big Ford show coming up next month on the 5th. I am taking both Mustangs, and maybe my Pinto. I will start detailing them next week :rolleyes: Brian knows where his tool is at if he needs it :D
