bluevenom867
I will have images of molesting stuffed animals in
Blown95Cobra said:I'm gonna use a turbo since I can crank up the boost on race gas and then turn it down on pump. I had thought about a blow through setup but I'm not sure yet. Is there any reason you chose a blower over a turbo?
Duh,there much easier to set-up,I mean just look at whats involved with a turbo...
Blower is basicly a bracket,head unit,pulleys and belt.If you want ot control boost with a switch or thumb wheel,get a electronic blow off valve,it can dump any excess pressure.
Also,a supercharger will really pump up your top-end.Because unlike a turbo,the more rpms your turning the more boost your making.So you can use a smaller cam,more streetable cam,and shift like 1000rpm higher than what the spec sheet might call for and still be making great power (were as a turbo might fall off a little on boost).
But turbos are cool too,its just I get tired of hearing about how there the best and crap like that.And I would hate to change plugs on a turbo car.And they get hot and burn stuff....
This is why I run nitrous...
