Any one running this cam? Could I run this cam without problems?
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,600-6,500 RPM
Intake Duration at 050 inch Lift: 232
Exhaust Duration at 050 inch Lift: 240
Duration at 050 inch Lift: 232 int./240 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 290
Advertised Duration: 282 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.565 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.574 in.
Valve Lift with Factory Rocker Arm Ratio: 0.565 int./0.574 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: FW XE282HR-12
Quantity: Sold individually.
My setup with this cam will be:
Stock 302 Block
GT40P heads or thumper ported E7
Stock rockers but eventually 1.6
Explorer Intake
BBK 75mm trhottle body with TF elbow
Underdrive Pullies
Off road H-pipe
Shorties
40 series flows
15 degree timing adv.
3.73
AODE
Stock 302 Block
Explorer Intake
Underdrive Pullies
Off road H-pipe
Shorties
40 series flows
3.73
AODE
