I intend installing the TCP power rack and pinion in my '66. My car has the Pro-Motorsports vario-camber setup installed, which uses an eccentric to adjust camber via the LCA. The eccentric is contained within a flat plate which is welded to the chassis area where the LCA bolts to the chassis.
The TCP rack assembly appears to use this use this bolt hole to locate the inner mounting bracket, and it is possible the vario camber welded plate which is sitting proud of the chassis will interfere with the TCP mounting bracket.
Any knowledge as to whether this will be a problem ?
