Borgeson Universal has now developed and is producing an integral power steering conversion box for the 1965-1970 Ford Mustangs. This is a remanufactured modern power steering gearbox that has undergone extensive modifications to be a direct bolt in for 1965-1970 Mustangs.
The Borgeson conversion box will fit with NO modifications to the shock tower and is a direct bolt in to the factory mounting location. Conversion box is being offered with either a 1" or 1-1/8" sector shaft to fit the original pitman arm.
Column modifications are required as follows. 1965-1967(Early) Mustangs with non-collapsible column will require a replacement column shaft, new column floor mount and complete rag joint. 1967(Late)-1970 Mustangs with factory collapsible column will require factory column to be collapsed about 2" for clearance and a 1/2 rag joint.
IMPORTANT NOTE #1: Borgeson conversion box will NOT fit with factory Z-Bar style clutch linkage.
IMPORTANT NOTE #2: Borgeson power conversion box will operate with stock Ford pump however the power assist will be minimal below 800 RPM. For enhanced response and drivability we offer a Saginaw P/S pump upgrade.
Please add any questions you may have to this thread. These boxes are ready to ship however may not be readily available in distribution for a bit. All components needed for complete conversions are being produced and offered in to distribution by Borgeson.
Thanks, Jeff
Borgeson Universal Company
Thanks, Jeff
