Awesome....
Will it do Burnouts?
It will not do a burn out from a stop. Can't power brake one either just stalls the torque converter.
Haven't wired line loc yet but don't think it well help.
Has made a little chirp in the 1st to 2nd shift going up hill and on some right hand turns.
Very pitiful. Let the speed parts begin already.
But over all its fun to drive and gotten good comments every time I stop it.
Now that it runs.
1. Today, tire side wall ruptured.It had some bad cracking on it so not surprised. Just part of being a old square tire. So need some new ones.
2. The oil has turned black as 'that cold bitches heart, from the past' who shall remain nameless.
In only 30 miles too, So want do a engine oil flush thing.
3. Trans seems to leak from everywhere but the front and rear seals. shifts a little erratic. Suffers flair up on 1 to 2 shift.
4. I think i hear a rumbly wheel bearing but shakes so much can't tell. New tires will make it so I can listen better.
5. All 4 wheel center caps must of shrunk a little because they are all lose and go clunky clunky at slow speeds.
First up carb swap to a bigger two barrel. Just got to rebuild it and carb kits are scarce out here.
1.08 287-CFM vs, 1.21 356-CFM
If it works out then about 70 -CFM more.
