429 Swap?
Tayler Neudorf
Hey guys, young builder her looking for some advice. I currently have a 68 coupe with a 289, and am looking at a 429 4v from an early 70's ford 800 truck. Just wondering what the difference was form the truck 429 to the car 429, and if it was even worth considering swapping it.
  • Sponsors(?)
horse sence
That $5 hooker turn out to be a guy
Mod Dude
3,677
233
Wile Coyote's stunt double
Way to much weight for the front end to handle with out a lot mods ,i would go with a 351 w or 351 c before i would do a 429.being from a ford truck it is probably a 460, same thing just more cubic inch
Tayler Neudorf
Thanks, I was originally planning on getting a 351w, but and being given the 429 from a friend. Any idea what would all need to be beefed up in the front end to support the 429?
horse sence
Mod Dude
3,677
233
A lot of structural work,the weight and torque would tear it up.you would need frame rail connectors for a start and you would probably have to modify the spring towers just to get it in there. You would probably have to modify the tranmission tunnel at the fire wall to get a big block automatic in ,the bell housing is a lot taller than a small block .Motor mounts are completely different so you would need to fab those. Exhaust manifolds /headers would probably be a problem also
Tayler Neudorf
Ok, kinda was expecting to have to do the engine mounts, frame connectors, and shock towers. Didn't realize that I might have to modify the tunnel for the transmission
Mustang68mustangs
Im new here. Sorry I couldnt stand all the misinformation in this post. Seems some people have no clue what is involved in this swap but continue to give bad info. I can tell you all you need to know about the swap. It is very simple and no major surgery or super duper bracing and crazy mods needed.
Bob
Reactions: 1968cobrajet
Tayler Neudorf
Any info would be great Bob. I'm not in a rush to do the swap, but would like to get an idea on what needs to be done to get the 429 in. I was planning on stealing the whole wiring harness with the engine, along with the engine mounts. And would a c6 mate properly?
Mustang68mustangs
A 385 series engine will fit easily into a 67 and up mustang without shock tower mods but notching them will help plug changes greatly. A c6 will mate up perfect just make sure you get one from a 429/460 or a 400m. Headers are readily available from crites restoration, FPA has shorties. There are others. Crites has mounts and tranny mounts. If your gonna drag race it small block springs work good or moroso trick springs.
With aluminum heads waterpump and intake the weight wont be a big issue. Transmission tunnel mods are not needed with a c6. A c4 will give you lits more room but unless they are built pretty stout it wont live behind a built 460 very long.
Dont get me wrong its a tight fit but very easy swap. Go for it. Hope you have lots of money for back tires! Any other questions ask.
Bob
horse sence
Mod Dude
3,677
233
The problem with putting a 429 / 460 into a 67 with out strengthening the front is
The front end is not built to handle the weight much less any added horse power with out modifing the front end.
A 67 only has one torque box in the front and the other side is simply attached to the floor and the fire wall this causes the frame rail to lift in the front ,so you will need to ad the other torque box to ,you can see this by the door to fender gap on most 67s being wider at the bottom and tighter at the top ,i have had to put a lot of 67 on the frame straightener to fix this. You can ad the other torqur box to strengthen that frame rail .
The next problem is the spring towers ,they crack easily enough with a small block,the extra wright ads more leaverage to the towers and can cause them to lean in or crack with out reinforvement .
Body stress from the extra weight is also a problem it usually causes a crack at the top of the windshield post and on coupes will crack at the quarter behind the quarter window. Frame rail connectors will help stop this.
A small block with a C4 weighs in at around 610 lbs ,a 429/460 with a C6 wrighs in at around 825 pounds so around 215 lbs extra added to those towers a rails
To not reinforce it is a big mistake.
I havent built just one car ,i have built around 175 Mustangs from 64 -73 so i have seen what extra horse power a extra weight does to these cars
Mustang68mustangs
Mustang68mustangs
I agree horse sence. It definately is a good idea to reinforce the front end and chassis. I have a 10 point cage that goes through the firewall and is tied into the shock towers as well. Also bolt in connectors that are welded. I was just trying to help the man with the swap not discourage him. There are thousands of mustangs of all years that have had this swap done. With aluminum parts a big block can be brought into stock small block weight range. Most guys that do this swap are not road racers and are not looking for maximum turning capabilities. They are drag racers. Like I said if anyone wants any input on the swap im happy to help. HAVE A NICE DAY.
BOB
Thread starter Similar threads Forum Replies Date
L 67 mustang 429 cj c6 to t56 swap help 1965 - 1973 Classic Mustangs -General/Talk- 2
F Heidts Mustang Ii Info And 429/460 Swap 1965 - 1973 Classic Mustangs -General/Talk- 6
K 351C SWAP TO 429/460 Classic Mustang Specific Tech 5
automart Boss 429 motor swap Classic Mustang Specific Tech 24
K Q's on Swapping a 429 Classic Mustang Specific Tech 7
TrickFlow Is there a Kit to Swap a 429 into a 86 GT ??? Fox 5.0 Mustang Tech 4
S 429 swap? Fox 5.0 Mustang Tech 13
S Expired 1971 Mustang Fastback --429 Cobra Jet Ram Air ---4spd ---mint !! Classic Mustangs For Sale 0
Waketek516 Boss 429 Scoops 1965 - 1973 Classic Mustangs -General/Talk- 0
B 68 Mustang 429 Hood Clearance 1965 - 1973 Classic Mustangs -General/Talk- 4
striker911411 Advice Needed. 351 Or 429? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
Doug Nash SOLD Msd Pro-billet Street Distributor #8477 For 351c, 351m, 400, 429, 460, Classic Mustangs For Sale 2
MRaburn Twitter Shelby Gt350: 526 Hp & 429 Lb-ft Of Torque. StangNet Site News 1
65fastbackresto Engine 429, I Found 2 Of Them, But I Don`t Know What They Are Worth. Classic Mustang Specific Tech 6
E Can a 429 go in a 69 M-code Mustang? 1965 - 1973 Classic Mustangs -General/Talk- 4
whitey68 Sweet Ole 69 Mercury Marquis 429 64xxx Miles Other Classifieds 0
Steve Granitz 1969 RED BOSS 429 LIKE NEW MANUAL Classic Mustangs For Sale 0
B 1969 Boss 429 Clone .... for sale Classic Mustangs For Sale 0
H '71 429 Engine Other Classifieds 2
F Polaris Drag Team 1971 Fastback Pro-Stock Mustang w/Boss 429 "Uncle Sam" Classic Mustang Specific Tech 0
MBGT02 429 Cobra Jet in '02 mustang SN95 4.6L Mustang Tech 5
M 1970 MUSTANG/COUGAR 429 CJ Q-JET CARB #7040288 Engine and Power Adder 0
C 429 Fit? Classic Mustang Specific Tech 3
D help!!!CAN I PUT 1 429 IN A 67-68 STANG 1965 - 1973 Classic Mustangs -General/Talk- 4
P 429 foxbody? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
M Boss 302/429 and Shelbys Classic Mustangs For Sale 0
S My 429 Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
Decurion Boss 429 heads, 460 block Classic Mustang Specific Tech 2
gingerbreadman camshaft failure in my 429 Classic Mustang Specific Tech 1
gingerbreadman 69 429 edelbrock intake, casting flaw or press fit fitting? Classic Mustang Specific Tech 5
A 69 w/ 429 CJS HELP!!!! Classic Mustang Specific Tech 37
Decurion Boss 429 rear main seal Classic Mustang Specific Tech 2
E Dropping in a 429/460 in a SN95, got some questions SN95 4.6L Mustang Tech 6
jdetten 429 in a fox Fox 5.0 Mustang Tech 2
S My 429 Fox project Fox 5.0 Mustang Tech 7
69gmachine Boss 429 shock tower assemblies Classic Mustang Specific Tech 6
gingerbreadman 1969 429 timing curve questions Classic Mustang Specific Tech 2
Decurion WANTED: boss 429 mustang Engine and Power Adder 0
66blue mustang boss 429 vs 428 cj? Classic Mustang Specific Tech 15
M MAC SS Catback $429 1996 - 2004 SN95 Mustang -General/Talk- 8
gingerbreadman help me identify this 429 in my backyard Classic Mustang Specific Tech 17
jerry S NPD Boss 429 hood scoop Classic Mustang Specific Tech 4
gingerbreadman 33 dodge coupe, 68 tbird 429 balancer questions Classic Mustang Specific Tech 1
tamadrummer88 429 Thunderjet into 68 fastback Classic Mustang Specific Tech 21
K BOSS 429 Classic Mustang Specific Tech 3
D 429 or 302 Fox 5.0 Mustang Tech 2
Decurion Boss 429 question Classic Mustang Specific Tech 1
4 Base model 69 fastback to BOSS 429 conversion - How costly of a conversion? 1965 - 1973 Classic Mustangs -General/Talk- 11
Whytry91 5.0 to 429 conversion Fox 5.0 Mustang Tech 25
Bosko5.0 347 or 429 what do you think? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
