RedDaemon
E-mailed them numerous times and they responded very fast! They just told me to swicth all three wires in the plug around until I got the highs/lows to come on at the right time.
and the result?
Shipping time wasnt really all that bad. Ive ordered dual a dual beam 9007 kit from them and a single beam 880 kit for my fogs and both work and look great. Really simple to instal just plug and play. Only hard part about it is trying to figure out where to mount the ballasts.
the bulbs in the headlamps are not the same light bulbs used in the fog light lamps.
so i could get away with ordering some 880 bulbs, and a dual beam kit for the 9007's, and then swap my current ballasts down to my fogs, and then just swap the bulbs out and it would work?
doens't matter anyway, im not ordering from them, for some reason I can't pay with my paypal, so I will just order off of ebay, im not messing with them. if they can't have a working shopping cart and payment function, then screw 'em. all i get is some error message saying my address doesnt match up with my paypal..but I haven't changed it, and it shows it's the same.
ok guys, got a question. A while back I ordered the single beam ballast kit, from a seller on ebay...not related to VVME. I got the 8000K kit for the 9007 bulbs...and installed them for my regular lights. Now I am wanting to get a Dual Beam Kit for Headlights, and move the single beam kit down to my foglights, but apparently the bulbs are different???
so do I just need to order 2 new kits, 1 dual beam and 1 single beam, and then just sell the other kit that I had previously?
Thanks
EDIT: I am putting on an 03 Cobra Front Bumper and Fogs, so which bulb works for the 03/04 Cobra Foglights?
Well I don't want you to quote me on this but I've never had a problem with blowing any part of the kit whilst looking for the right wiring combo.
My Expedition took like 3 hours(it was 30 deg. F outside) of frustration until I tried a combo that worked.
Your talking about the three wires that go into the stock headlight plug right? I just wired mine up and they don't work but I tried switching those wire in the plug but I don't know how to switch them around without cutting the wires and just twist and tape them back together. How did you change the three wires around.
Thanks,
STeve
Make sure you are changing around the three wires from the HID kit and not the factory harness plug, and no do not cut the wires it is easy to get them out without cutting. Get a very very small screwdriver or possibly a paper clip and straighten it out. Use this to poke into the backside of the clip to release the wires. They are held in there with retaining clips, just be careful not to break anything and take your time.
I may go ahead and order a set for foglights and headlights today. Is there any issue with the heat generated from these using stock headlamps?
