SmockDoiley
Gear banger you are still an idiot. He said the engine has head work, has a cam and an intake and its fresh from the machine shop. Sounds built enough to me for serious power.
Your T-5 argument is retarded too. That crap transmission wont hold on a stock 302, let alone a 351 or a 460, so anyway you look at it, horsepower means a new tranny. But in case you are wondering, a T-5 will bolt to a 460 and so will a Tremec. How do I know, oh yeah, I bought the clutch, pilot bearing, bellhousing, spacer plate and TKO600 and they all bolt up. Oh Im sorry, I was too busy reading Car Craft to mention that. Speaking of which, those guys dont know anything right? They just print engine articles with detailed parts breakdowns, dyno graphs, parts prices and where to source them because they are talking out their asses? But Im too retarded to do all that myself, but I guess I am because Im the only one on Corral.net and stangnet whos mated a 460 to a Tremec as far as I know. There are a lot of words Id love to say to you for your blatant ignorance and attitude. Tell you what, go ask the hundreds of people who have dropped a 460 into a fox body. They drop right in clown. You havent done the swap, but I guess you know anyways.
As for prices:
Intake--$190
headers--$220
cam--$150
performance heads--$50 plus $250 for machine work
Engines-- 2 460's and 2 C6's for $350.
Where the hell do you get off saying parts are more expensive and Im stupid. Yes, big block heads are expensive, but if you knew anything about the D0VE-C castings or the A429 head you'd know you dont need aftermarket heads to support over 1000 horses. Last I recall an intake for an EFI 302 cost around $500 compared to the $190 I paid for my carbed 460 intake. Go drive your mustang off a cliff with you in it if you even own one before you start questioning my knowledge of auto mechanics.
And as for the blower weight. Its an estimation and comparison between an iron headed 302 equipped with an intercooled supercharger and an aluminum headed 460. The weights are nearly identical. My headunit with just the main bracket, weighs 30 lbs. The intercooler weights 17. That isnt including the over 6 ft of 3 inch diameter steel plumbing, other brackets, power steering relocation bracket, oil lines, BOV, MSD BTM and the hardware to bolt it all up. An iron headed 302 with my supercharger setup weighs 520 lbs. A 460 with aluminum heads weighs 540. Wow, 20 lb difference. Even with iron heads its still only 120, and by relocating the battery to the rear and going to a fiberglass hood if you choose, your back to within a few lbs again. I didnt spend over 5 years working on jet engines in the Marine Corps, studying automotives my whole life and now 1 year away from finishing my mechanical engineering degree to be called out by a clown such as yourself. Do some homework before you open your mouth because at least I do. This kid is but a mere $100 C6 tranny, and $500 worth of swap parts away from having a 12 second mustang. Last I checked thats less than a set of Thumper ported heads for a complete drivetrain. Oh yeah, forgot the $75 to get the driveshaft shortened. Go buy a rice rocket loser since you dont know what you are talking about in here.
As for prices:
Intake--$190
headers--$220
cam--$150
